1 - 9 of 9 Posts
This is the first I have seen of these. I am wondering just how low the one over the exhaust goes. I have all of GT Specs braces and the 6 point brings the cars lowest point doen somewhat.
Hopefully not that low.Judging by the color of the suspension, he is rolling on TIEN coilovers.
they shouldn't be too low for the ground clearence. but I am not sure if they will fit NA 6, since I think the 6 in the picture is not a NA model.
I'd give them a try, and I think they will fit. Bignoze6 you bought that GT Spec brace for the rear that was said not to fit the NA model and it fit yours perfectly.
I have measured the both front and rear yesterday, I believed the front one will not fit cuz of the fat resonator in our 6s. The rear one is just the same concept of that 2 GT tiny bar, but I think the one showed above has more benefit than the GTs since it connected across the chasis. As you may see, the car installed above pretty sure is a asian 6, which our 6s has a way more complicated and thick exhaust, therefore, the rear one may not fit as well. I would bet it should be fine with the 6i.
1 - 9 of 9 Posts
