1 - 3 of 3 Posts
I have a 2009 Mazda6 with the 3.7L V6 that I got in June 2009. Starting about a 6-7 weeks ago, when accelerating casually, it shifts normally at 40 mph (I believe it is shifting into 4th gear) and about a second later the rpm drops from 2000 to around 1500 (which it didn't used to do) and then there is a rattle in the engine. Is anyone else experiencing this or know what might be the cause of this?
Interesting.
The 1st gen is in 5th by 40 and goes into 6th at around 42. In 6th the rpms will fluctuate a bit around that area. I always attributed it to the torque converter going in and out of lock-up. Never really thought about it much.
But the rattle I can't explain.
QUOTE (Spazdog @ Jan 17 2010, 06:49 PM) index.php?act=findpost&pid=1630432
Interesting.
But the rattle I can't explain.[/b]
You are right. I have been paying attention to the shifts and it is shifting into 5th at 40 and almost immediately shifts into 6th gear. The rattle I believe is the valves I'm hearing when the engine is under load at such a low rpm. I'm going to be passing this info along to the dealer. I know this wasn't happening until several weeks ago. Thanks for your reply on this.
1 - 3 of 3 Posts
