I have to revert to OEM stock so that I can take my Speed6 in for warranty work. My 2nd gear will half the time go in like normal, half the time you pull into 2nd and let the clutch out and it grinds out of gear. The feel is like this.....
You know you pull the shifter into a gate to get in a gear and you feel it pass the resistance and it goes to the point where it will naturally fall into the gate on its own......sometimes it goes past that point of resistance to where it goes the rest of the way naturally.........and some times I feel it barely get to the very peak of the resistance and it stops solid there. I know when I feel this that its going to pop out. I have even attempted to hold it back in gear with my hand just to mess around....and when I lean on it a bit it will pull my hand forward and start to grind as it leaves the gear.
1600 miles.
I have to strip the intake, water/meth system, boost control, and a few more things. I wonder if its purely a linkage issue, or if its sync failure? Any one else seeing this kind of issue? I have been driving this car hard and pulling off a good deal of full throttle 6000 rpm power shifts thru all 6 gears, but with only a couple miles on it I dont hardly think that is the issue. I have beat on many cars just as hard for many thousands of miles and not had a tranny failure......I hope this is simply a fluke! BTW I do think I may have a busted engine mount as well......but I am not going to mention that. I'll take care of that the old fashioned way.....in the shop.
1600 miles.
