1 - 20 of 22 Posts
2015 Mazda 6 Sport
Before starting this trek tomorrow, I will be doing the routine check up of tire pressure, fluid levels and emergency supplies.
I run 38/37PSI; just back from 1750 miles, Houston to Saint Louis and back for a week. Pulled down 35-36MPG on the freeway and 30MPG around town. Have fun and be safe.
2015 Mazda 6 Sport
Looking forward to numbers like that on my California to Washington road trip!
I took a road trip from NJ > Kansas City > Chicago > NJ this past winter and the Mazda6 is a champ! I made sure I had every emergency supply I could need in the trunk and never needed any of it.
Do you have an air pump in the trunk?
2015 Mazda 6 Sport
2015 Mazda 6 Sport
Have you plotted your route yet?
If you're taking I-15 through Vegas continuing on up through St George (SW corner of Utah) take a break and I'll treat you to a meal. I'd guess you're gong to cross the country on I-70, 80?
That’s a really nice offer! Unfortunately my route is going to be majority by I-5.
2015 Mazda 6 Sport
No air pump, but maybe I should invest in one?
I strongly suggest you get one. Imagine you're​ in the middle of nowhere, and you found out that you have a leaking tire. Vulcanizing shop is miles and miles away.
After some time, the tire is so deflated. But you have your donut tire, that should save you.
Can you imagine the hassle?
And that spare tire should be inflated to 60 psi. That's a lot. Most people don't think to verify that thing...
I always have a small air compressor in my car.
BTW just completed a couple of trips (two this month; here's the fuelly log. The second included a fair bit of mountain driving.
Mazda 6 Sport MT (Mazda 6) | Fuelly
This car has no problem exceeding 35mpg on the highway at all and reaches into the upper 30s if you're not doing mountains and similar excursions. My usual on road trips where the land is reasonably flat is in the 37-38mpg area.
2015 Mazda 6 Sport
Discussion Starter #14
Stats before making it to Washington
Odometer read 53,070
Avg MPG 26.2 (10 mile commute to work all city driving and I drive with a heavy foot)
Count me in that statistics. This is my first time to have a donut tire and I didn't know about 60 psi. I'd like to verify this with the manual.
I've also reached those freeway numbers before, but we're usually high-balling across TX and AR on I-30/67 then again on 55 in MO.
If you're not getting into the upper 30s on MPG you're really hauling butt -- I normally cruise at ~73-74mph on the highway (assuming a 70mph speed limit.) Note my car is OVTuned; when I bought it originally I noted the ECU tends to come out of "partial Atkinson" mode around ~71mph, which is a REAL problem as that costs you ~2-3mpg immediately when it happens -- therefore one of the adaptations I requested specifically is that the transition be moved up a bit.
It matters as this allows me to run just under 75mph on flat land and NOT lose the better-mpg calibration. If I'm out in the far-west where you have 75 and 80mph speed limits (e.g. west of Dallas, basically, or for that matter north of Flint on I-75 in MI) then I eat the penalty in fuel economy.
On trips where I've been forced into ~60mph operation over full-tank periods of time (e.g. the NE in many cases on turnpikes where they'll actually nail you on clock time from entry to exit -- yes, I got a ticket that way many years ago back when the toll tickets were PAPER) I've managed to break the 40mpg barrier. The other place I've approached or exceeded it is in CO; at higher altitudes many stations sell "Regular" that's 85 (as opposed to 87) octane and the SkyActiv engine burns it just fine without detonation but with a material improvement in fuel economy -- even with the mountain driving component of it present.
2015 Mazda 6 Sport
Discussion Starter #19
Update:
Made it on Friday afternoon.
Odometer reading: 55,294
Avg MPG: 30.3
Highest miles driven on one tank: 609
2015 Mazda 6 Sport
Discussion Starter #20
Update:
Made it back Monday at 6:10pm (39 hours of driving omg)
AVG MPG: 31.2
Odometer: 56,546
Highest mileage on one tank: 515 (I was driving much faster this time around)
1 - 20 of 22 Posts
