So there was a discussion before from a thread recently going back and forth stating that the 2014+ Mazda 6 no longer employed sensors at each wheel and instead used the wheel sensors to determine if a tire was low on air via rotation speed. That is no longer the case.
Take note 2018 owners, we now have TPMS sensors on each wheel. I only figured this out because I was looking at the valve stem and it's the typical metal valve stem that TPMS sensors have. So I checked in the owners manual and it confirmed that there are indeed sensors on each wheel. So if any other 2018 owners out there are planning to do a wheel swap, keep in mind that you will have to swap over the sensors now. Was kind of a bummer because I liked the idea of easily swapping out wheels without having to pop the tire off. And not having to deal with the permanent batteries that dead every 30kish miles requiring replacement of the whole sensor.
