1 - 8 of 8 Posts
The central locking has recently started to malfunction - when you try to unlock the car with the key it does unlock sometimes but then produces a number of loud clicks (sounds like it is trying to unlock but just keeps repeating). One time it did not unlock and I had to leave the car for 30 minutes but when I returned it unlocked ok.
I have sent a copy of a video of the problem that I took to Mazda UK but they have no idea what the problem is - has anyone else experienced a similar problem?
The motor or solenoid or whatever you call it is most probably the problem.
I'm confused. Are you locking the car while the door is open? I'm on my bed right now and I can't increase the volume of my phone.
To answer your question earlier, the picture I showed you is individually installed on your doors. So, you have one for each door.
I really suspect that the actuator is the culprit. My suggestion is to locate where the sound is loudest. You "open" that door.
When I say "open", you remove the door panel so that you can access the actuator. You now check it if it's working properly.
No, I am not locking the door while it is open - the video shows what happens when you unlock the door using the handle button. I have played around with it today and if you lock and unlock using the key fob its ok.
Everything in modern cars is computer controlled. Just for the hell of it, try pulling off the negative cable on your battery for a few minutes. See if that doesn’t reset something in case it’s a software issue and not a hardware issue. Who knows, it could be a safety interlock, loose ground wire, it could even be the routine that detects a fob that is left inside the car. Again, thoughts off the top of my head but it could be a software issue.
Interesting point about it being a software problem as I had it serviced 3 months ago and whilst I was not informed that a software update had been done I noticed that all my usual settings had disappeared and I did think that something may have changed. Because I have not used the car much due to the coronavirus outbreak I didn't notice the problem until recently - I will have a word with Mazda UK but thanks for your thoughts.
1 - 8 of 8 Posts
