1 - 9 of 9 Posts
Hey all! I was replacing the stock brake bulbs and couldnt help but notice there are no wires running into my rear deck speakers! I purchased this car used w 30k miles so not sure if this was removed or if rear deck speakers ever came on the 6 sport model. Seems off. Idk how i never noticed this. My question is did this model come with rear deck speakers and if so how should i go about finding the wiring? Also there is a random wiring harness unhooked behind the rear seat. Help! Thank you
240046
240047
Have fun with the deck cover trim; you have to remove several other pieces of trim and things from the interior rear seat area to get it out without damaging it. While you're doing it add a small amount of dynamat to the shelf metal; it resonates like a SOB and will destroy the sound quality if you don't. (Can you tell I've been in there?)
I opted NOT to put speakers there in my car; YMMV.
Yea, why? They are so low in volume even on a Bose car that i just pulled mine out. Plus, i need the holes for when i put my subs in...
Thanks a lot, I was able to remove it all safely just to take a look and it all went back in place fine. Gunna take that your route and opt not to waist time on the rear deck. May install a 8in sub at some point for more punch. If so ill add some insulation to that deck and truck area. Ill post if i do!
Just an idea glad you informed me that they are negligible lol in some cars the rear deck makes all the difference (last car was a altima and the stock lows were great) im glad this is not the case
Check out my build log for ideas, especially with the rear deck Audio build log
For sure i checked it out, im deciding on a material if not just using dynamat but its a little expensive
1 - 9 of 9 Posts
