41 - 45 of 45 Posts
Anyone found a cheaper battery option?
I just used a O'Reilly's Platinum AGM battery. A little over $200 with core. Everything is working fine, including i-eloop. Better specs than the OEM enhanced flood battery.
The main issue is having the battery sync done after the install, as i understand it. But, did you read the posts?
What "battery sync" do you speak of? I just disconnected the plug on the negative current sensor while switching out the batteries.
I just used a O'Reilly's Platinum AGM battery. A little over $200 with core. Everything is working fine, including i-eloop. Better specs than the OEM enhanced flood battery. What "battery sync" do you speak of? I just disconnected the plug on the negative current sensor while switching out the batteries.
Its in the owners manual... ;)
41 - 45 of 45 Posts
