My Ac runs out of 134A in about a month. Is there a common leak. I tried a dye and AC leak checker. The leak checker slightly reacts if pushed into the evaporator drain hose. The dye is not the kind that shows under black light.
M mitro6ual 488 posts · Joined 2018 Add to quote Only show this user #2 · Jun 28, 2022 My schrader valves gave out. Easy fix but you will need a vacuum to refill the AC.
