1 - 1 of 1 Posts
My master window switch no longer controls my rear drivers side window AND that window only goes DOWN not up with the switch on the door. I'm guessing I need to replace the master switch as both the motor and switch from the rear driver side door work fine on the rear passenger door.
My dealer says that the part number I need is GP7A-66-350C, which is $221 special order. I have found a part on ebay that is $45 that may do the trick. I just need to know from someone who knows part numbers if this cheaper part will truly be compatible with my vehicle. The part number from ebay is GP9A-66-350. Any help would be appreciated.
1 - 1 of 1 Posts
