1 - 7 of 7 Posts
how can larger 2006 front brakes (rotors, pads, clips, calipers...?) be adopted to 2003 model?
I did rent a 2006 v6 and braking was way superior to my 2003, stopping power had less fade, was quiet, smooth and powerfull... with no vibration or sqeel every time!!!
How expencive would it cost, what parts would have to changed to 2006 spec and what could be kept from 2003?
considering costs from mazda for stock parts, you are probably better off doing a TCS BBK
Never underestimate the power of stupid people behind the wheel. They'll be wrecked in junk yards soon enough.
that's a good point, but do we have any idea about what exact parts of the breaking system are needed to perform a swap from 2003 to new 2006 specs?
rotors, pads, calipers, clips what else?
mounting brackets? master cylinder? might as well go with braided lines if you're doing this.
I should of thought of this instead of spending so much money last year on brakes. Well not that much but still its money I put out. I ended up getting new slotted rotors, Hawk pads, braided ss lines, and DOT 4 brake fluid, and im still not happy with it.
Its a great improvement over stock, but the pedal fading at high temperatures still sucks, and it could use a little more initial bite!
A big brake kit would have been awesome.
I'd ask one of the site sponsors that works at a dealership to research part numbers, start at the spindles and work outward until you find dissimilar.
1 - 7 of 7 Posts
