1 - 12 of 12 Posts
Just would like some help on hose routing, every workshop and service manual I get some how finds a way to leave what I need out. Got my 6 used obviously, they had stuff all over the place and I’m trying to make sure the hoses in the back of the plenum both upper and the one kinda hidden. Additionally they have a t in my coolant line attached the the lower end of my throttle body that certainly isn’t factory so pretty much where all the coolant, water pump, heater core, and bypass hose are routed to. It’s a lot I know that’s why searching google for hours has gotten old and it doesn’t seem like I can find a single v6 in my area to look at.
Could you possibly post some pics? That would help a lot.
I’m thinking the tee you’re talking about should probably look like this, it should have a line coming off of the bottom of the throttle body mine is just capped because I eliminated the coolant lines going through it. A very simple mod if you wanted to do it btw.
That’s the tee I’m talking about. It’s dark out now so I’ll probaly take some pics tomorrow. Is their a reason you have one side blocked off? And where’s the other side go to? Mines literally a copper pipe tee for house water lines. But more importantly I need to see the hoses going to the plenum and where they go.
I’ll try to take some pics of the intake tomorrow, dark here in Ohio too gotta hate this time of year lol. That part of the tee is blocked off because it was for the coolant line running through the throttle body, I deleted these because on these cars they really don’t serve much of a purpose so by getting rid of it you decrease the intake air temperature especially if you have a cold air intake like I do therefore increasing power. The other line I THINK goes to the heater core I will confirm this tomorrow when I take the intake pics.
I have seen a lot of those with household tees in junkyards, they break really easy I broke mine when changing my spark plugs I bought mine at autozone you can also get them from rock auto I’ll put a link at the end
https://www.rockauto.com/en/catalog/mazda,2007,6,3.0l+v6,1434579,cooling+system,coolant+hose+connector+/+flange,11566
i believe that hose routes coolant through nipple on the throttlebody and intake. those lines are very misunderstood. people think the hot coolant increases intake charge temp so they block it off thinking it 'll lower IAT sensor readings. other people live where it's warm and delete it because they think it prevents throttle body icing in winter and they don't need it. both of those groups are misinformed. the actual purpose is to cool the EGR passage and lower intake temperature once the car is up to temp. it's part of the COOLING system. it fights heatsoak. exhaust gas is a lot hotter than 200° and that hose keeps the passages the hot EGR gas passes through in check. depending on the car and how long it's driving you may have an intake that is a hell of a lot hotter than it should be with that disconnected. if you delete the EGR system, it is safe to discard those coolant lines. if EGR functions, those lines should function as well. i have studied this quite a bit and i deleted those lines and the EGR system on my foxbody. not because i wanted to get rid of EGR, i like EGR gas and i wanted to leave it so could try to inject extra for mpg while cruising. unfortunately in 1992 car computers didn't have many extra sensor inputs. in order to datalog my air fuel ratio i repurposed the input wire from the egr's EVP sensor as described here: eectuning.org/forums/viewtopic.php?t=14947
new guy here. not a know it all, just a car guy that is always learning and willing to get in over my head. my profession is a signmaker. i'm just chiming in because i know those lines and their purpose.
Not sure if the egr portion applies here, on these v6s the egr is not at all connected to the tb and it is located after it so the gasses go directly into the intake, those coolant lines only run through the tb not the intake. But this is an interesting piece of information that I did not know before.
where does the coolant exit the mazda intake(or tb)? i've never even SEEN the engine yet.
on dodge neons and 01-02 pt cruisers the passage is very obvious in it's purpose. the PT on the left it goes in and runs all through the intake. you can see the egr passage on the TB in my pic. the mustang one on the right the coolant only circulates the egr spacer. i had quite a few civics, they were similar to the PT in that the coolant would flow through the intake but i was young/dumb when i was a honda kid so IDK where the coolant was flowing in relation the the egr gas.
now you have me curious to see where the path of coolant goes after it enters the mazda TB. what would the coolant there do? i'm sure you're correct, now i'm curious what it cools(or heats?).
nobody has really been able to come up with a definite answer as to what the coolant actually does it literally only runs in the upper inlet on the TB (only running through the TB) then exits it on the lower outlet if you look at the pic I posted earlier in this thread you can see the upper port. some think its there to prevent ice ups at extremely cold temps.
I have no way to find it, but someone on here, years ago, who was a bit of a scientist figured out the cooling effect on the air entering through the venturi of the TB. He posited that the temps could concievably get near freezing and thus his assumption was that the coolant lines to the TB were there to actually keep the TB from freezing. I challenge someone to find that post in the archives to see if my memory is any good ?
You are exactly right. It is more of an altitude thing, at lower altitudes under 1000' sea level there is very very little chance it will freeze. Over that the risk increases exponentially.
It is from the venturi effect, the pressure drop cause a sharp temperature drop.
Discussion Starter #12
Alright so here’s what everything in there looks like. Keeping in mind this is how I got the car with the exception that it had a terrible Ingen cai without the performance maf and that was causing serious problems.
1 - 12 of 12 Posts
