My display works fine until I crank the car, then the display goes blank!
Hello, generally the display will go blank when starting the car. It should however resume function after the engine is running.
If this is not the case does the display work when the key is in both the ACC and ON positions?
The display works in the ACC and ON position, only goes blank when the car is running!
Opps I replied in the wrong spot sorry!
Possibly a communication error between the instrument cluster and the display. Something possibly with the tachometer circuit. sorry but that is all I can think of.
I would unplug the connectors from behind the info display and the two from the instrument cluster and re-attach them in the hopes that it is a faulty connector.
