21 - 24 of 24 Posts
Discussion Starter #21
No, that would be a reasonable temporary fix fine for a low pressure line. You would probably use a barbed splice and clamps yes?
You'll spend $8 on the fix or $6-$15 on an aftermarket hose.
The part I am unsure about is when you said hole in the metal. The metal is the pressure line and you would need something like this.
In addition to a pipe cutter.
About $30 to repair that.
I would replace the line.
Good Luck. (y)
It’s definitely not a pressure line , the one end I can see is clamped out a hose coming off the bottom of the power steering pump with a clamp then it runs along the bottom of radiator , to me it looks a power steering cooling line or return
Discussion Starter #24
Will this work for power steering fluid ? Searched the forums and found lots of different answers
21 - 24 of 24 Posts
