I have been looking all over and cant find any specs for the rod bearing bolts. Anyone know what the specs are? Thanks
Not sure how much info you don't have (like clearances, spec for rods, mains, balance shafts, shims, etc) but here is the info... also you can grab the FSM - follow my sig and the instructions in the first post.... Pn 1731–1E–02C PS - looks like your gonna need a degree wheel. And I didn't find it in bold print but it has tell tale signs of torque to yeild bolts which are almost always discarded and never reused.
Connecting Rod Cap Assembly Note
Caution
• When assembling the connecting rod caps, align the broken, rough faces of the connecting rods and connecting rod caps.
1. Tighten the connecting rod bolts in two steps.
Tightening torque:
(1) 26—32 N·m {2.7—3.2 kgf·m, 19.2—23.6 ft·lbf}
(2) 80°—100°
Main Bearing Caps Assembly Note
1. Install the main bearing caps in the order indicated in the figure.
Tightening torque:
(1) 44—46 N·m {4.5—4.6 kgf·m, 32.5—33.9 ft·lbf}
(2) 175°—185°
Cylinder Head Bolt Assembly Note
1. Tighten the cylinder head bolts in the order indicated in the figure in six steps.
(1) Tighten to 5.0 N·m {51 kgf·cm, 44.3 in·lbf}.
(2) Tighten to 13— 17 N·m {1.4 —1.7 kgf·m, 9.6—12.5 ft·lbf}.
(3) Tighten to 44— 46 N·m {4.5 —4.6 kgf·m, 32.5—33.9 ft·lbf}.
(4) Tighten 88°—92°.
(5) Tighten 88°—92°.
Camshaft Assembly Note
1. Install the camshaft with No.1 cylinder aligned with TDC position.
2. Tighten the camshaft cap bolt using the following two steps.
(1) Tighten to 5.0—9.0 N·m {51.0—91.7 kgf·cm, 44.3—79.5 in·lbf}.
(2) Tighten to 14.0—17.0 N·m {1.5—1.7 kgf·m, 10.4—12.5 ft·lbf}.
CORRECTION: bolts can be used if they meet spec;
BOLT INSPECTION
1. Measure the length of each bolt.
• Replace any that exceeds maximum length.
Length L (from inside shoulder to bolts end)
Bolt Standard (mm) {in} // Maximum (mm) {in}
Cylinder head bolt 149.0—150 // {5.86—5.90} 150.5 {5.92}
Connecting rod bolt 44.7—45.3 // {1.75—1.78} 46.0 {1.81}
Main bearing cap bolt 110.0—110.6 // {4.33—4.35} 111.3 {4.38}
Caution
Tightening torque:
(2) 80°—100°
Tightening torque:
(2) 175°—185°
thanks for the info. Imma pass this on to my mechanic. We need to sticky this cause I have searched all over google and these forums and this is the only info I have seen.
googlize this as typed....
"mazdaserviceinfo" L3
