Other than the output, what are the differences between these two engines?
Are they completely different?
Are the turbos different?
Or is it the same engine with a different map loaded? If so can you change the map?
This is about the diesel engines right?
So.... is there a way to change the mapping yourself so no tuning company gets involved os is the mapping hardcoded?
(I think I know the answer but #daretoask ;-))
Rob
existing versions are available in two power levels 129 kW (175 hp) and 420 Nm (310 lb·ft) and 110kW (150 hp) and 380 Nm (280 lb·ft). The two versions as far as I heard are mechanically identical. The difference between them is less than 10 tables in the ECU.
Anyone know a Mazda specialist who will put the 175bhp map onto a 150bhp car?
I take it, less than 10 tables just means it's a different map loaded.?
