Hi, last two days on my commute to and from work there has been an issue with with a power drop after 2.5k revs, car seems to stumble and jerk. But returns to normal under 2k rev. This seems to be a bigger issue in the higher gears but might be my imagination. The engine rev's fine through the range when the cluch is in.
The commute is 13 miles each way. part motorway and part town so the engine get a good warm up. But issue seems to stay for the whole journey.
Here's the car details.
'04 Mazda 6 Diesel 2.0 121.
110k Miles.
Replace the EGR value around 1k miles ago.
No warning lights (the check engine one went off when the EGR was replaced).
Oil levels are fine and checked twice a week (not going up or down ~ excessivly).
I did notice that the coolant was a little low so that was topped up today.
Likely I need to replace the SCV as it takes a bit of commitment to get it started on a cold day (runs fine when warmed up - i.e. doesn't stall when coming off the motorway which I've heard can also be an issue with an dodgy SVC).
I've listened out to see if there are additional turbo noise, but can say I hear anything out of the ordinary (no extra whistling etc).
What would the likely issues be that I can diagnose myself before I take it to a garage? Any suggestions appreciated.
MOT Road-tax and Insurance are due in a month. So if it's going to be expensive now would be best to find out, so I can get rid.
Cheers!
110k Miles.
Cheers!
