1 - 20 of 22 Posts
Im trying out the new supernova led's,they have a heatsink built in that is supposed to keep them from burning out in a high heat application.
The reason they are burning out is that the heat from the headlights is frying the led's.
autolumination.com under the 194 section,i think they are the second ones as you scroll down.They do require modification to fit in the housing,pm me and i will give you details
I see the picture you have of it with the light on, but can you provide a picture of it off but really close up, I want to see what it looks like off from the outside.
not a problem,I will get a pic up tomorrow.It's already dark here in kansas
I have spaced it off completely.You want a close up daytime pic.They are holding up just fine and are very bright.I will get one taken tomorrow.sorry guys.
Is there any LED that works inside the day time running light that will not burn out? [/b]
i believe if you read the warnings from most 194 LED bulb distributors, they warn against using them in applications like the sealed headlight assembly because of the heat generated by the headlamp bulbs. that's why your bulbs are burning out so quickly
the thread is now about the 194 supernova bulbs that have a heatsink for higher heat applications.
Hey I just posted in the other 194 topic. I bought the Supernova's now I need to figure out how to get them to fit in. How did you get them to fit the housing? What did you use to notch the heat shield?
I still had one functional and after talking to the guy from supelumination,I found out that you can destroy leds if they are on when you start the car.I figured if i had one burned out i might as well test the theory.Sure enough,i had my drl's on when i turned it over and it started strobing almost instantly,it failed within 20 minutes.So i can confirm that a voltage spike killed it.
1 - 20 of 22 Posts
