21 - 22 of 22 Posts
Ok so I have been having an issue with my Speed6 not wanting to start. Sometimes it will start and sometimes it wont. The crazy part about the the whole thing is when I jack the car up it starts fine. When I put it back on the ground it will start maybe 3 times straight , then I'm back to square one Nox Vidmate VLC of no starting. It also did start after I put it into gear while I had it on the ground, but then that failed as well. Any suggestions would help. Thanx in advance
Wiggle the key while you are attempting to crank, if that changes anything it could be that switch.
21 - 22 of 22 Posts
