I have 06 Mazda 6 manual transmission I took the transmission out replace the clutch replace the throwout bearing replace the slave cylinder I put everything back together prime the clutch and I can't get the car to go into gear can someone help me
Assuming you bought the right disk, with the correct thickness, the most obvious reason would be that the disk was installed backwards.
Did you check the travel of the slave cylinder?
Ok, so that is a totally different issue to what you initially described.
First you said you could not get the car into gear (clutch too tight) now you are saying the engine revs and the car doesn't move (clutch slipping).
Which one is it?
Don't know how to discribe it but it doesn't catch when you relieve the clutch so I put the shifter in gear and when releasing the clutch I have no movement
So it is slipping.
Why did you replace the clutch? Was it slipping before? Did you check that the pressure plate was good?
Only thing you can check at this point is to verify that the slave cylinder is seated properly and retracting when you release the pedal. Besides that, you'll need to take the transmission out and check that everything was assembled correctly, and maybe check your pressure plate.
Attached is the clutch section from the workshop manual.
Hope someone else chimes in and maybe has other suggestions.
Dam I didn't want to remove that tranny again and yes I bled the slave cylinder I'm allso thinking about the shift barring so thanks to all that replyed I'll keep the forum updated
Hey Bros! I found a good car. I want to buy a car via incacar.com/used/cars/mazda/6/2016-Mazda-Mazda6-696001 but I´m a bit worried about that, just if they are reliable. What is your opinion?
My Fuel Economy Has Improved Dramatically
EDIT BY MODERATOR: There is nothing wrong with this post, but I am frankly tired of the millions of new threads that are created regarding the fuel economy of the Mazda 6. So whether your MPG is good, bad or average, post about it here. I will close...
Is there a way we can watch our car's travel on our computer at home in case it is stolen? I'm sure it's possible for someone whith the know-how but I just wondered if it was possible without having to buy a tracking service like lojack etc. After all the car is essentially being tracked already...
Nissan's VC-T engine essentially alters the compression ratio by changing piston stroke distance while you drive to go from high compression ratio while cruising under light load, to a very low compression ratio during full throttle acceleration to increase knock resistance as well as turbo...
