Greetings all mazdaheads ^^
So I've been trying to add an AUX input on my 2002 Mazda6, alas, without any luck...
The problem is, I can't even get the TAPE/MD button to work - I've jumped pins 1 and 13, I've soldered the 0 Ohm resistor on the HU (L716 mod), but it still doesn't do anything, I don't even hear the beep when I press the button.
Maybe someone could shed a little light on connecting pins 1 and 13? I've found this diagram:
Pin 1 is 2A, pin 13 is 2M, so basically, according to this pinout, I'm connecting common ground to nothing and that should enable the media button? Shouldn't pins 8 and 9 (2H and 2I) be used to actually enable the aux input?
Also, does someone happen to know the pinout for the connector that sylfex uses? This one: (This is not my HU...)
I figured that if my only chance on getting aux is to buy sylfex or something like that, why not make one myself? As far as I know sylfex is nothing more than a board with a little preamp on it - it amplifies the signal and feeds it into the actual HU, so it shouldn't be too hard to make one. In fact, you could make one and spend not more than 20$...
